De Restrict / Unlocking the Shimano e7000?? BEST WAY?
twistgripper
66
39
Canada
Stunlocker much cheaper and work really well.
ST unlockers website says " the best way to rise the Speed Limit is to change the destination market to US (32km/h)." - only 32kph? does it not unlock to 50kph like others?
lightning
715
410
Presumably by selecting a smaller wheel
size?
My wheel size was set at 2350 mm and l measured it at an actual 2260mm
For now l've just altered it to the correct size, which has made the speedometer on the bike more accurate.
And l assume a little bit faster along the ground, maybe 5%
lightning
715
410
I will answer this myself, as nobody has responded and l've actually tried it myself now.
Yes, you can make the bike faster by changing the wheel size.
Although l only set mine to the actual size. lt was set at 2350mm and the actual wheel
is 2250mm.
After l did this the bike was about 0.75mph faster along the ground and the speedometer was a lot more accurate.
Before it was claiming 15mph when my GPS said 14mph.
lightning
715
410
Well yes it is if you want to completely derestrict the bike, while still having correct speed readout on your display.
All l wanted was to get the full 15.5mph that l had paid for, and not 14.7mph
RickBullotta
1,847
1,579
Stunlocker will work for a software-only approach to get you to USA spec. If you choose to go another route, please don't be a d*ck and ride 50 kph on multi-use trails. That's a great way to get eMTBs banned.
554K
