Hi,
my CX Gen 2 recently started slipping under load on technical sections at low speed, now also when going uphill over small roots or rocks. I can hear cogwheels slipping, motor rpm increases for a second with no power transferred and then it reangages.
Bearings are also failing, as it is producing a grinding sound and there is play in the cranks, especially on the non-drive side (I replace the protective felt rings and add grease on the drive side quarterly)
It’s a 2.5 year old motor replaced on warranty with 10.5 K km on the clock. It is now out of warranty.
What can be the cause of the motor slipping and can this be fixed while also changing bearings or do I need a new motor?
