Waynemarlow
Constantly variable transmission set around the mid motor is on its way. Note the 200Nm, way over the top and I wonder what it weighs
Every CVT car I've driven I've hated. Despised. Sure I'd feel the same way on a bike. Nothing wrong with gears.
Gordon
I think that belt/chain driven CVT (prone to breaking) are not as good as eCVT such as the Toyota, which uses motors to change the ratios, good video showing how it works if your interested - if this could be miniaturised to fit ebikes then maybe this would be the way to go?
eCVT seems to be the best transmission for parallel hybrids..toyota/Honda/ford. you can combine the gas engine and electric motor power, run on pure electric, do Regen, or charge the battery, smoothly switch between those different modes while simultaneously acting as a reliable and efficient CVT without belt, and ECU has full control over the rpms to continuously optimize power or efficiency like cvts with actuators (unlike scooter/mopeds using weights/springs that you need to tune with a compromise between acceleration/top speed/efficiency) no shifts/ loss of power but you can also simulate gears in manual mode.Every CVT car I've driven I've hated. Despised. Sure I'd feel the same way on a bike. Nothing wrong with gears.
Gordon
ecvts don't have a belt rubbing power and potentially slipping. plus you have a perfect chainline all the time unlike 1x12 losing lot of efficiency when using short/long gears.Drivetrain efficiency is terrible with CVT's. The power loss to the ground/wheels is huge.
the motors are able to Regen, like any electric motorCVT in motor scooters is amazing. There is so much more available power, and much less weight. The big downside is no engine braking - kind of like an emtb.
I did come across this shaft drive system with gears - it is still in it's infancy
one possibility is the tech is not refined enough for production. this will be expensive/low production so people don't want to pay big money for an ebike with weird pedal assist feel or transmission the other is that it's not easy to innovate and be cost effective against Shimano/SRAM. if the technology is so great, it will eventually find it's way to mainstream but it could take years. Shimano also has various internal gearbox patents under it's belt(although quite different from ecvt) they can wait and see, make the most money from current generation of 1x / electronic/wireless shifting, see the long term reliability/issues and sample the acceptance of the technology from early adopters, keep lobbying/pressurize big bike manufacturers to boycott this kind of tech, maybe wait for the company to go bankrupt and buy the patents on the cheap, before partnering with specialized/trek to make flagship ebike frames compatible with it.I wonder what the trouble is with the Revonte? Is it investments, sabotage, or does it just suck? It should have been here by now.
coolI use that exact same system from Grin on my drop bar eBike except I activate the regen via a momentary button switch attached to the left brake hood. Whenever I want to slow down it is the first thing I reach for because it acts like a brake drag basically. When bombing downhill at 30+mph with gravity doing it's thing it is often the only braking force I need but if I need more the brakes are easily at hand.
But other than that the amount of energy it puts back into the battery over the course of a battery cycle of around 30-40 miles depending on the terrain I am riding with a 500wh battery it might provide me with at most another mile of distance if the ride was in hilly terrain. However it does save on disc pad life and for the type of riding I do with that bike I would miss it if it wasn't enabled.
I don't see regen happening for the eMTB market anytime soon if ever but for road/gravel bikes I wouldn't spec one any other way.
