Cube Stereo Hybrid One55 Silly Issue
Mad_Angler1
49
80
Hay folks. Got the 2024 155 last week and absolutely loving it so far however I have one silly little issue with the dropper post.
It seems the cable routing is a little tight as when I'm turning the bars left it seems to be pulling on the cable and releasing the post as if the leaver is pushed.
The cable goes into the rh side of the head tube though a little rubber grommet so turning left is pulling on it is little and causing it to release. I have tried adjusting the cable but it then does not work when I turn right or even in the centre. it seems it's a little tight when turned left and to loose when turned right.
Now I can stop the issue by pushing the cable back into the frame a few inches however it's just working it's way back out again a few minutes later and starts all over again.
Has anyone else had anything like this, right now I'm trying to think of ways to keep the cable in the frame and stop it working out. I could put a cable tie between it and one of the other cables externally but frankly I don't want to.
It could do with something inside tbh to stop it pushing back out but not sure.
Silly issue I know but any thoughts would be great.
Thanks.
556K
