CUBE Stereo Hybrid 140 - help choosing rear shock
P3t3r
North
I currently have Cube Stereo hybrid 140 HPC Pro 750 with following parts:
Front: RockShox Recon Silver RL Air, Tapered, 15x110 mm, eMTB Approved, 150 mm
Rear: RockShox Deluxe Select, 205x60 mm, Rebound Adjust, Trunnion Mount
However those shocks isn't that good. Feels like they are not there yet what I want after trying to tune them properly.
For front I was thinking following:
RockShox Lyrik Ultimate Charger 3.1
But for rear shock I dont have any clue. So many choices from Rockshock selection. Budget is 400€ and I'm 87 kg/191 lbs. Any recommendations?
I should have bought bike with better parts but at that time I didn't had the money.
EDIT:
this might be:
RockShox Super Deluxe Ultimate RC2T
At least it fits for the budget and the reviews seem good.
Mister cube
80
50
Isle of wight
EDIT:
this might be:
You can get the super deluxe ultimate for it,it will be much better,sadly you cannot put a coil shock on it as the gap between the shock and seat stay is too small and the spring may rub,i was told this buy TF tuned,the ultimate is the best shock for the bike
Mister cube
80
50
Isle of wight
You can get the super deluxe ultimate for it,it will be much better,sadly you cannot put a coil shock on it as the gap between the shock and seat stay is too small and the spring may rub,i was told this buy TF tuned,the ultimate is the best shock for the bike,as for forks,i have 160 mm domains on mine which are much better.
573K
