Cube Reaction Hybrid Thru Axle
Bundit
9
Aberdeenshire
Hello all, got myself a Cube Reaction Hybrid EXC for just over two weeks now and I'm loving it. I have been using for mainly commuting not have the time to take it for a long weekend fun as yet. I have recently fitted Acid Mudguards but during the process of putting everything back together I stupidly overtighten the thru axle. I've managed to get the axle out but the allan slot have sustained damage. The axle come fitted on my bike is a NEWMEN 12x148. Any idea if this the same as X-12 syntace specified by Cube themselves? Any help would be greatly appreciated.
Jackware
Fat-tyred Freakazoid
2,046
2,252
Lancashire
Hiw about this;
The picture's wrong but the measurements seem correct?
Maxle axle 004318005025
Kingfisher
90
76
Belgium
If you managed to round a hex slot, put it in a vice, get a bigger Torx bit and hammer that in the hole. Remove with pliers and you now have a torx fitting for your bike
Jamy
206
122
rotherham
looking at the dimensions the Syntace X-12 seem to match. I would give them a try
SYNTACE Thru Axle X-12 148 mm Boost, 34,50
Panayotis
FRANCE
+1 Jackware for the Robert Project!
I am looking to replace my thru axle Newmen 12x148 Y1279 for pulling my kidstrailer Thule Cross 2 and i made a mistake buying a shimano m12x1,5 thule thru axle 20110734
Because i am full shimano, i thought my thru axle was shimano too! Error
Pitch is 1.0 and conic, so it is Syntace 20110733 which is compatible for my bike
Thanks to Jackware, i found the magical Axe Finder
Axle Finder - The Robert Axle Project
And for you Bundit, this one should fit
Lightning Bolt-on Axle - Rear 12 mm x 168-173 mm x 1.0 Thread - The Robert Axle Project
Bundit
9
Aberdeenshire
Thanks for the great informatio
I have also been looking for thru axle to allow me to attach kids trailer. You just pointed me to the right place. Much appreciated
  • Like
Reactions: MsO
Bundit
9
Aberdeenshire
@Bundit
Check Bike Discount
Thule Thru Axle 160-172mm for Syntace 12x1.0 acheter | Bike-Discount
And Thule Adaptater Fit Guide
https://cdn1.static-tgdp.com/assetloader.axd?pimid=20110729&id=583408&brand=Thule&market=FR&att=1
NB: on my Thule Thru Axle, it is written Thule Axle by Robert Project. Made in USA!
Thanks for the link Panayotis. I've found a UK distributor for Robert Axle Project and will placing an order with them soon. The link you've provide above come with a flat washer. I think my need taper one as it's x-12?
Bundit
9
Aberdeenshire
My new Syntace x-12 axle finally arrived. My next question is, Do I need to grease the axle as the current one have some sort of grease on it and what type of grease should I be using??
Panayotis
FRANCE
Just receive my Thule Thru Axle 20110733
(Syntace 160/172 M12 X1.0)
Fit Perfectly with my Cube Reaction Hybrid EXC 29 pouces full Shimano
Bundit
9
Aberdeenshire
Very nice, I like the colour of your Bike, I was looking for the same colour but unfortunately I couldn't get them anywhere in the UK (not for a few months anyway) so ended up with grey/green one instead.
gavcav
21
7
Leeds
Hi Bundit, how is the rear mudguard attached at the bottom bracket area of the frame? is it bolted or is there an adapter? i've just bought some and they are for a bolt attachment, but my bike doesn't have a bolt position there to secure it and there is no adapter.
551K
