It's all in the title, if you experience creaking noise in the BB/motor area and if you've already check the cranks, pedals and chainring then the noise is probably simply coming from the motor bolts.
Just clean every threads in & out and torque the bolts at the correct Nm (22) with a bit of blue Loctite.
