I have 2020 Orbea Wild FS H30. The right side crank bolt keep coming loose. First time i notices it after about my 4th ride. I tightened it without torque wrench and it came loose the next ride. I torqued it to 35 ft. Lbs, and still came loose after the next ride. Then I put blue loctite and torqued it this time to 40 ft.lb. It came loose after 2 rides. I took the bolt out and cleaned it completely. Put a blue loctite and torqued it to 45 ft.lb. Came loose again after 3 rides. I don’t often get a pedal strike. In fact very rare. Out of al those rides only one ride had multiple pedal strike.
Should I go back to LBS and ask them to figure it out? Or am I missing something? All these time the left crank bolt never came loose once!
