Mark02380
Now "Mark24" 👍
Can anybody help can’t seem to connect to Bluetooth, followed all the youtube vidoes the option just isn’t there on my Decoy Pro
Hi thank you for your reply, I’m using Apple iPhone, when I go into the settings on the Shimano display the option for Bluetooth isn’t there, so I’m doing something wrong or the bike needs a firmware updateSo far do you have Android version 9 or 10, don't forget to activate GPS as well on your Smartphone before starting the App.
On Decoy is Bluetooth activated approximately only for 10 seconds after your switch on process or after changing the support (e.g. from ECO to TRIAL).
That mean, only while this time should your App recognize the Decoy.
And to be sure, switch off Bluetooth of all other devices nearby (e.g. no second Smartphone activated).
Hi the bike is brand new only received it on ThursdayI'm sorry, I'm not familiar with Apple devices.
Have you (or the previous owner) ever been coupled your Decoy to any devices or Apps?
If yes, maybe a 6-digit code number was defined and stored in Decoy. You have to know them if you connect in future to other devices.
Hi thank you for your reply, no nothing is showing up, even when I go into to settings on the display there is nothing about BluetoothYou are giving just too little information to help you out. First of all, you cannot connect the bike via Bluetooth on your phone directly, say as is connecting a headphone. You will have to pair the SCE7000 (screen) first though. Each bike or motor rather has a pass code. You'll need to set this once. Stock pass code is usually 0000.
Bluetooth connection is only possible within the E-tube Shimano app. Also there is information within the app about connections.
Do you see the SCE7000 in your Bluetooth list after you start the bike?
