ictin
Hi,
I got second hand Cannondale Mavaro Neo 4.
It has a Bosch performance line gen 3 engine.
According to the manual ( https://www.cannondale.com/-/media/...689mavaro-neo-tesoro-neo-trail-neo-omsen.ashx) it has a daytime running light. But the previous owner for some reason cut the wires of the daytime running light.
Now, I will want to reconnect it. But I have no idea how. The manual specify that the functionality of the daytime light is independent of the front and back light and will work when the system is on (not requiring the lights to be on), but the schematic from the manual show the front light connected to the daytime light. The daytime light has 4 wires: 2 in and 2 out fot 6-12v (I don't know why)
When I opened the inside, I see that the input wire from the motor was connected to both front and back light, and no other wires. From what I found in the manual from the sticky post, the motor has output for front and back light, activated from the display, but no connection for continuous power.
I connected the daytime light in to input wires, and is turning on, when I turn on the lights, and the sensor is turning it off when is too dark. But still is not as intended: to turn on independent of the lights during the day.
So the question is: how I can connect the daytime light to have power when I turn on the display?
