Unanswered Command Post Fix?
martinf
32
19
Brighton
My Specialized Command Post IRCC 125mm keeps dropping randomly. The cable/lever set up seems fine. Can the post itself be fixed/repaired? At the moment I’m looking for a replacement, but if it could be fixed relatively easily/cheaply then obviously that would be preferable. Thanks
EPicko
Home
I had exactly the same issue with mine. I dropped the battery out and fed the dropper post cable through to the seat tube a little - I wanted the seatpost a little higher, there's no slack to allow this unless the cable is pulled though a little. Works perfectly now, cost=£0!
martinf
32
19
Brighton
Thanks, I’ll try that, but I don’t think it’s a cable tension problem as it was quite loose at the lever end until I took up the slack with the barrel adjuster
martinf
32
19
Brighton
Thanks, it’s pulling smoothly so I don’t think it’s that. I’ve tried what Epicko said and will try it on a ride tomorrow, thanks for your advice, Martin
578K
