Coil shock for 160 tm
Doug85
55
13
yes i have the 160, so you need the 205x60, indeed 65mm
regarding spring rate see above what i used for my weight
Hi, slightly confused with this you have the 160 same as me mine has a 205x65 the 140 comes with 205x60 so do you have to reduce your travel to 150mm in a coil on the 160mm?
578K
