Swissrider
I accidentally pumped out one of the pistons in my code R brakes today. I managed to get the piston back in but as I had lost some fluid I had to bleed the brakes, which was overdue anyway. Having bled them, I am having a problem with brake rub - the pistons don't retract enough and there is virtually no play at the lever. The brakes work well but are being slightly applied all the time. I also bled the back brake and this is fine. I have taken the pads out, pumped the pistons our, lubricated them with brake fluid, pressed them back in and replaced the pads but the problem remains. So, I don' think the pistons are sticking. Should I let a bit of fluid out? And if so, at the lever end or the caliper end? Thanks.
