Ark
if I lift my bike by the top tube as the rear wheel lifts off the ground there's a small clank that sounds like it's coming from where the rear suspension attaches to the top tube.
also feels like there might be 1mm or so movement there
I'm not sure if my bikes always been like that or not?
I did some research and it seems it's probably the Eyelet bushing that's worn, is that normal on a 3 month old bike that's done 500miles and never seen any big jumps or abuse?
From what I gather I need 1/2 x 1/2 bushings and the sram tool to squeeze them in?
also manual says you need 2x torx keys, I don't actually need 2? I can just undo them one at a time? then when I tighten them back up switch back and forth between the 2 sides until they are both at torque?
