Charger wiring
Dave Rand
111
145
Kent Uk
Hiya. I’m needing to put a charge Dc Barrel plug in my frame (normally just unplug the battery) for external charging.
I take it I can just wire the charger Dc wire straight into the back for the main wiring m600 motor discharge wires?
Waynemarlow
1,106
888
Bucks
No, almost certainly the BMS will have its own negative connection wire.
Dave Rand
111
145
Kent Uk
No charging connection on the Daley BMS.
Waynemarlow
1,106
888
Bucks
Some do and some don't have a seperate Negative input for the charger ( most are seperate ), you will need to know exactly what BMS you are using and then look up the manufacturer specs.
552K
