charger 2.1 conversion in Rockshock Lyrik
Cavi
376
123
California, usa
for those who have don the conversion from the lyrik select to the 2.1 charger. What was the difference. I mainly ride trails, not really any jumps. So I am looking for improvement on the low speed bump absorption. Smaller rock compliance improvement both slow and at more speed, improvement on deflection on rocks while railing down a trail Then the next question. RC2 or RC3, seems the RC3 is better and less money....
Gary
Old Tartan Bollocks
10,496
10,702
the internet
IME it won't actually be hugely more compliant than the charger damper you have already. Especially if you are a heavier rider. The compression damping should be subtly lighter but for a heavier rider running a higher fork spring pressure this difference will be less noticable. What it will add is more adjustability in the form of separate low/high speed compression damping adjustment.
Unless you're a lightweight rider and genuinely struggling with the fork being overdamped I'd save yourself £200 and just do a lower leg service to freshen up your small bump sensitivity.
Doomanic
🛠️Wrecker🛠️
8,698
10,330
How did you reach that conclusion?
The RC2 has high and low speed compression adjustment, the RCT is a single adjustment for compression damping which is why it's cheaper.
The RC2 is more tunable, but that will make it harder to find the best settings unless you're a suspension guru.
Cavi
376
123
California, usa
thank you.. after more reading that is exactly the conclusion I also did come up with!!!! I will save the money
552K
