Changing suspension
avman
41
15
hull
Hi all
Changes to amflow pl and was hoping to change over to factory fox front and rear shock I have a spare rear dpx2 160mm seams too long it maybe a 205mm
if you have changed over rear shock which one did you go for and how did it affect the bike.
Also I’m toying with going
factory 36 160mm grip 2
or
Factory 170mm 38 fit4
I have both to try problem is the existing headset has a weird fork crown washer I can’t get off the existing fork
Cheers
Jon.
avman
41
15
hull
it physically wont fit hence me asking what and if others have replaced the shock with, TBH i will probably leave it i was replacing it as i already had one available to me
im more intersted in the 170 38's vs the 36's 160
Weeksy
551
578
Reading
Cheers
Jon.
At the bottom where the steerer meets the upside down U shape ?
That's called a Crown Race and makes the headset bearing 'fit' and meet correctly. You need a tool (or a screwdriver and a hammer, please don't)
561K
