Rail (750Wh) changing forks.......
Dave_B
1,467
1,593
Newquay
Is the crown (I think that's what you call it) on the Zeb bigger for the Rail than what would be on a standard Zeb fork? I think @Rob Rides EMTB mentioned that Trek requested the bigger crown to match the headtube dimensions on the Rail?
So if I changed to a different fork, it would look a bit silly if the new fork had a smaller crown?
irie
2,557
2,599
Chichester, W.Sussex, UK
IIRC the Rail Zeb with the larger crown is an OEM special supplied only to Trek.
I have Pike Ultimates with the regular crown and my wife's Rail has larger crown forks, both 2022 bikes. Looks fine, you'd only see the difference if your bike's next to another with a larger crown, and even then you probably wouldn't even notice unless you were looking for it.
Paulquattro
2,305
1,284
The Darkside
As above i also changed the forks and to be honest i dont notice or even care for that matter, but i also run different make tyres and wheels front and back as its what i had in the garage
I know that would drive some people mad :)
Stihldog
Handheld Power Tool
3,527
4,948
Coquitlam, BC
Yes! That step between the fork crown and steering tube would drive me crazy 😜. I looked into the Zeb Ultimate and the Trek OEM fits the steering profile better. The son-in-law installed a Fox 38 on his large Rail and the step is obvious …to me. ($1700 cdn btw…I’m gonna re-think this).
Dave_B
1,467
1,593
Newquay
I'm waiting to see when the charge 3 damper and debonair+ upgrades become available in the UK before I decide what to do. Not sure I could live with dodgy aesthetics. I know @Rob Rides EMTB special ordered some larger crowns from FOX for his 38's.
scooby82r
81
47
Manchester, England
170mm front - (Over stroked the rear)
554K
