RacerX
Hello out there. It looks like I will need a special crank arm puller tool to change my crank arms on my Bosch CX for Orbea Wild. Is that correct?
I have a crank puller for motorcycles, but instead of messing around with it decided to buy the Park Tool CCP-44.View attachment 136274
I modified a cheap PITMAN-ARM puller for a car, just had to grind down the tips a bit so that they would slide between the crank arm and the motor, remove the retaining bolt and insert a small socket so that sat at the end of the crank shaft and presto, off they came with a few turns of the bolt. You can pick up one of these pretty much any cheap auto store or on line, this was advertised for $14 Australian, about 7 pounds UK or about $9 USA.
