Change Marzocchi Bomber Z2 from 140mm to 150mm travel?
eddomak
20
14
Hi all,
I have a Rise H30 and was wondering if there is a way to change the Marzocchi Bomber Z2 140mm to have 150mm travel instead? (I note that on the Marzocchi site for that fork there isn't a 150mm travel option, so don't know if there would be such a part.).
Thanks in advance!
Stanley
30
26
Stockport
Just fit one of these I believe.
I've done similar with Rockshox forks. Easy job
eddomak
20
14
Thanks - I will look into it. I've done Rockshox forks before as well. I was hoping someone had travelled (no pun intended) this path already to see if it could be confirmed. I might just need to be the guinea pig...🐹
LoneStar
16
10
Atlanta
I've done it, it's easy. The fork does feel more flexy at 150mm but YMMV.
My feeling as well. Got a Lyrik and like it much better for the longer travel. The Z2 wasn't bad at 140 so I'll probably change it back to that to use on another bike.
eddomak
20
14
Thanks both for your replies - good to know it's a tested route. I run a Lyrik Ultimate 150mm on my regular (non electric) MTB , and despite being a relatively light rider I do feel that it is sturdier.
552K
