joshhoward23
Has anyone in here changed a 2022 kenevo comp to a mullet Setup. If so has it affected the geometry in a bad way? Hence making the handling poor?
Is that bad though?Lots. it raises the front 50mm and subtracts 1.5ish HTA
I've gone for a fox 38 170mm which I think others have done. Will see how it ridesI picked up 2022 Kenevo expert on the Covid sale. I pulled the Boxxer and installed a 29er Domain 180 mm. With a 27.5 wheel, this razed the front end 20mm. I also put the rear shock bolt in the high position to try to keep from getting to slack . At this point the top tube is really close to being to high to go mullet let alone full 29er. If you mullet the bike, I would recommend you go with a 160mm 29er fork. The cheap way with the comp would be an 160mm air shaft and a fox 36 29er lower legs.
How did you fix it? Assume you had the chip in high?I mulleted my Kenevo adding a Fox 40, which has about the same axle to crown as a 180mm 38. TBH it was fairly horrible for anything that wasn’t super steep. It was just too slack - I would unexpectedly wash the front wheel without notice on flatter turns in situations you wouldn’t imagine coming off.
the bike or the fox 40?I fixed it by selling it!
