Dazb
Well chain slip has been driving me mad so I tried changing the chain and that never helped so after a lot of YouTube research I have managed to sort it out, It turned out that when I set the B screw tension and using the SRAM gauge I never adjusted it allowing for the sag, So ratchet strap around the wheel hub and seat I tensioned it to set the sag at 25%, Once that was done I used the SRAM plastic gauge and adjusted the B screw and although there was only a small amount to adjust it has solved the problem
