Amygos. Chainring guard, bash guard and charge port cover all in one. Best investment I ever made for mine. The battle scars it has on it make me wince. I'm on 36t chainring btw
I am familiar with the Amygos but always wince at the thought of shipping it over here to the USA. I was just wondering if there were room for a traditional bash guard. But it sounds like, no.
Thanks,
Jay
There's no bottom bracket or ISCG on the frame, so these options are out of the window. You might be able to DIY something with a bash ring that is mounted to the crankset/spider with chain ring bolts and place it on the outside of the spider. Depending on the shape and bore diameter it might work.
On 3x cranksets you could swap the largest chainring for a bash ring when converting to 2x, for which you needed slightly longer bolts as both the middle chain ring and outer bash ring were mounted with the same bolts. Something similar would be needed here.
