Chain pop
mclydeg
34
16
Phoenix AZ USA
2019 levo
About 2-3 times per ride as I take off I hear what I believe is a single chain pop.
Bike shifts OK ??
Any ideas?
Thanks in advance
Mcg
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
2019 levo
Bike shifts OK ??
Any ideas?
Thanks in advance
Mcg
The clunk you hear mostly in Turbo, less in Trail & not in Eco?
I believe that's the sound of 100 Nm of rotational force of the Gates belt on the spindle though I could be wrong
salko
1,275
865
SLO
By this chain pop you mean the pop like the chain jumps for 1 teeth forward or if cassette will lost connection with a wheel and jump few degrees forward? After about 140km on 2020 TL I also heard this kind of chain pop 1-2 times ...
20,757
Mine makes this sound too .. (Kenevo). Not worked out what it is .. normally either when setting off or when suddenly going hard after going easy.
Murch
222
185
United States
Happens on mine and everyone I ride with too. We are not sure what causes it but I have gotten used to it. I do know it is coming from the chainring area.
ebikerider
706
484
It's just the motor taking up slack when you take off or when you have backed off the pressure on the pedals causing the noise. It happens more frequently in trail or turbo mode for me.
Jeff McD
344
375
Kona, Hawaii
Happened on both of my 2018 Levos and now on my 2020 S works Levo as well. Only happens in very tight technical terrain when I am pedaling slow in tight turns and really sounds like flex in the drivetrain causing the chain to ride up on one of the chainring teeth and then pop off. Keep waiting for the chain to break but hasn't happened yet ha ha. keeping fingers crossed.
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Honestly I don’t think this sound would be replicated so exactly by so many if it was the chain but rather transmitted through the chain.
Nobody has reported shifting issues & I don’t think anyone has reported the sound during a gear shift.
I strongly suspect it’s the same sound I’m hearing occasionally and my chainline doesn’t budge with the Rohloff hub. I don't think the chain is the cause - more like a lot Newton metres. I'd be interested to know if it occurs in cadence based Shuttle mode
Also interesting described as a pop. I'd say clunk. Sound transmission through magnesium differs to that of aluminium which could explain it being present but slightly different in Mag S & Alu S.
I tried riding with reduced Peak Power and it’s much less noticeable.
20,757
I'd say clunk.
I'd describe mine as a clunk. But maybe "pop" is the technical word ?
Anyway, had a short ride yesterday after converting to tubeless and didn't notice it once. Could be co-incidence but I actually tried to make it clunk once I'd noticed it wasn't doing it, by going from soft to hard several times and it didn't do it. @wepn has a rohloff and still gets it, so it sounds like it's chain related. I changed my front chainring last week and that didn't make any difference.
The only things I did which could make a difference was dropping the back wheel, I span the freewheel a few times whilst the wheel was off and checked things, converted to tubeless and put it back. So unless slackening the chain off completely stopped it somehow ? I had to re-adjust the rear caliper afterwards which seemed odd, you'd think it would all have lined up exactly the same ? So unless it's something unusual with the rear axle bolt, which is unlikely.
gaba
112
129
California
Probably unintended/unnatural movement of chain onto or off of teeth in your drivetrain. Could be a stuck/stiff chain link, bent teeth/tooth on your cassette or chainring, or poorly aligned chain line. I had a stuck link in my brand new chain on delivery. I used a chain brake tool to loosen it up and worked lube into it. That fixed my initial pops. Some amount of occasional noise from such a powerful motor is probably unavoidable as you use a flexible system that moves in so many directions, as things aren’t always perfectly aligned. Make sure you keep you drivetrain clean and well lubricated. Work through each link to ensure it’s moving well. Regularly check your cassette and chainring for damage. Try to shift with minimal tension on the chain (let off the pedals before you shift). Shifting in turbo for me took practice.
brizi2003
236
147
Whickham, Newcastle upon Tyne
Not sure
Just sounds like a single pop maybe a chain binding type sound
Not a skip
Could also be the freehub, they sometimes make a loud 'crack' from time to time when they are sticking a little. This normally occurs when just starting to pedal. Maybe try stripping the rear wheel freehub and cleaning & lubricating as per recommended for this type of freehub.
salko
1,275
865
SLO
Does any1 have a spare gopro or similar camera and try to catch this clunk on a video? I noticed this clunk quite often when I am on steep climb, in higher gear and usually in Turbo mode ...
Glen
36
28
New Zealand
Was frustrated with this happening badly. Always starting off or when under load. 11 tooth gear mostly. It was 80 % adjustment of derailleur end point with 20% derailleur alignment. Now gone completely.
Ps tried to video it to find issue but couldn't.
salko
1,275
865
SLO
Yesterday I have taken my bike to LBS to 1st service (have about 350km on the clock), told them about occasional clunk when under load, they say they will look into it ... today went to pickup the bike, they said they ckecked and made some corrections to derailleur and it should be fine now ... afternoon I went to a short ride, and well before first steeper climb I shifted to 2nd gear, put in turbo mode, double checked I was in 2nd gear and soon after starting to climb a *CLUNK* again, now I looked down and I was still in 2nd gear ... I'm now quite convinced clunks are comming from freewheel ...
DS.
85
58
Devon
My bike is doing the same thing and it’s a new motor didn’t do it with the old motor feel like something moves or slips and it’s not the chain or cassett
salko
1,275
865
SLO
Just been at LBS, told them it is still clunking, now they said this is completly normal for e-bike, "It's very powerful motor you know!". I don't buy this sh*t! :mad:
I will try to find a way to catch it on a video ... this just can't be normal ...
552K
