Chain jumping on bottom cog
Giff
459
127
Cheshire UK
Has anyone any suggestions. My chain is jumping my bottom gear (biggest cog) on my SRAM cassette.
I am on my second GX chain ( 25% worn) with the same cassette. I am using an AXS derailleur and all other changes are smooth. I don'y use this gear too often.
I have tried the micro-adjust on the transmitter....both ways but it changes into the bottom gear then slips back down. Anyone have any tips or helpful hints?
Jackware
Fat-tyred Freakazoid
2,079
2,293
Lancashire
Have you tried adjusting the stop screw on the derailleur?
Page 44;
Giff
459
127
Cheshire UK
Thanks Jackware I thinks that is it...I mustn't have set it up properly in the first place and only noticed this weekend when I needed bottom gear.An easier and cheaper solution than I thought !
aviserated
67
23
Oxford GA
I recommend you hot wax your chain to prevent premature cog and chain wear. Hot waxing attracts way less abrassive dirt than wet lubes. Lots of videos on YouTube about waxing bike chain.
You will know when the smallest cog is worn, because chain will skip ALOT in this gear no matter how perfect alignment is. Replacing cog/cassette and chain is only cure. Be sure to hot wax new chain.
554K
