Has anyone fitted a Chain Guide to a Whyte e160 rs......or any recomendations?
Which one did you order out of interest?Thanks Wilko58 i have contacted Whyte who said they think one should fit but haven’t tried it. I have one in order from Nukeproof so will post if it fits.....or not?
Cheers mate, shame it doesn't fit.Update on chainguide....it doesn't fit. It will rotate to line up the bolt holes but there isn't enough clearance for the guide.
Have you seen this post on Facebook, shows a chain guide fitted.Update on chainguide.
Have you another link to the Facebook picture or a screenshot, it says this one isn't available.Have you seen this post on Facebook, shows a chain guide fitted.
There was another post following that one which said they'd bought the last one but if it is ISCG5 it should fit?Have you another link to the Facebook picture or a screenshot, it says this one isn't available.
The one I posted from FB is on a Whyte e-bike, not sure which model but looks like Gen4What motor are you trying to fit the chainguide to?
Bosch gen 4?
you need an E spec guide.
it'll be a different bolt circle to ISCG05
The OP has just added "Two bolts only, the only tricky thing is placing the washers - need 3 or 4 to centre over the chain. I used grease to stick them together ??"Have you another link to the Facebook picture or a screenshot, it says this one isn't available.
The FB post is in this thread above. You've got two posts crossed, the Nukeproof doesn't fit as the OP found out but the one on FB is a foreign cheap ISCG5 one and apparently does fit.i don't have Facebook.
Nukeproof don't make Ebike chain guides
Keep reading - a new version is out in May to fit the Bosch bikes....it says not suitable for Bosch eBike?
