I thought that all but important stuff would be delivered by post or courier, if either of them are delivering then I’ll order tomorrow, thanks for the other suggestions, I watched a YouTube video and the guy used unleaded petrol, has any one else in here tried this.
Thanks for that James, I might just give that a try until my degreaser arrives, I have the Park chain cleaner and I totally agree it is a great tool ?washing up liquid works well. the park cm5-2 chain cleaner is awesome. I've scrubbed mine with a brush then done it with the park tool as a test, water was black, and chain felt much nicer.
I test it by twisting the chain and feeling for grittiness. The park tool is the only thing that makes it feel like new.
I have a pair of Park quick link removers, oh right I was under the impression you had to fit a new link each time the chain was taken apart, you see this is why I joined this group, to gain the knowledge ?I only intend removing the chain if it gets really cruddy or if I run out of chain cleaner and have to use something that’s not chainstay protector friendly, thanks for the help guys ?I doubt you need to use a spare link every time you remove the chain, as long as you use a good pair of chain pliers. In any case, with the Park Chain Cleaner you won't be removing the chain?
Thanks, I think I have some spare diesel in a container somewhere if my memory is playing ball ?I remove the chain quite often to clean. Quick links make it a doddle. I use diesel in a lidded container , put chain in, shake for a bit, empty the dirty stuff out and leave it to settle to use again. Repeat until no grit and crap in the diesel. You don’t need to use much, a gallon last many months. .
Spare links? I thought the master link was reusable many times!?Cheers guys, just ordered some degreaser off eBay, I intend removing my chain to clean it when it’s really dirty, I know I’ll need a shit load of spare replacement chain links but hey ho, I’m thinking if I can give my chain a good deep clean it’ll last longer and my drive train will last longer too.
Diesel or gasoline are still extremely effective, but not popular these days because they aren't 'green'.Thanks, I think I have some spare diesel in a container somewhere if my memory is playing ball ?
SRAM, I recall, recommend not reusing it on 11spd. My suspicion is that they wish to absolve themselves if there are any problems with it not done properly. As long as the right tool is used and the link is not damaged, can't see any issue.Spare links? I thought the master link was reusable many times!?
In my opinion, yes it is reusable. But when the chain is done so is the master link.Spare links? I thought the master link was reusable many times!?
This is the best stuff for cleaning the bike. I use a wax based chain lube and it will not remove the wax. I also own a truck and write it off on tax ?Petrol may not play nicely with some of the rubber chainstay protectors, also any hydrocarbon degreaser will be the same, alkaline degreasers are bad news for paint and clear coats.
I just use a heavy duty truck wash degreaser such as this:
Exactly that same asIn my opinion, yes it is reusable. But when the chain is done so is the master link.
I keep a few old master links in my backpack as emergency spares for other people that might need them. (I keep a new one as an emergency spare for me!)
Just so you know, Your opinion is wrong.In my opinion, yes it is reusable. But when the chain is done so is the master link.
Steve seen earlier on a particularly competitive group rideI keep a few old master links in my backpack as emergency spares for other people that might need them. (I keep a new one as an emergency spare for me!)
This is of course your opinion. A master link will wear as it has pins, a known fact is that a chain measured across a master link shows more wear than when measured across normal links - a good trigger to obtain a new chain. In any case why would you use an old, worn, master link with a new chain that comes with a brand new one?Just so you know, Your opinion is wrong.
The wear parts when a chain wears/lengthens are the chains rollers and pins. Not the outer chain plates.
your old quick link if re-used with a new chain fits into NEW (UNWORN) rollers.
Even if the pins on your old quick link are slightly worn (they most likely won't be BTW) one single link with slight play between the pins and rollers isn't really going to cause any issues at all.
This genuinely made me laugh
I prefer the old dropping tacks in their path trick.
no it doesn't.a known fact is that a chain measured across a master link shows more wear than when measured across normal links
Not all new chains come with a quick link.In any case why would you use an old, worn, master link with a new chain that comes with a brand new one?
Nice one mate, you’re advice is taken onboard and I appreciate your advice ?This is of course your opinion. A master link will wear as it has pins, a known fact is that a chain measured across a master link shows more wear than when measured across normal links - a good trigger to obtain a new chain. In any case why would you use an old, worn, master link with a new chain that comes with a brand new one?
