Can I put a Bosch Gen 4 motor in my gen 3 bike?
cablepuller1
12
GB
Hi,
Looks like my bosch performance line cx gen 3 is knackered and out of warranty, would a gen 4 motor fit in my bike or are all the mounts and connectors different
TIA
cablepuller1
12
GB
Thanks, will let you know, warrants has just run out so going LBS first, it's an electronic problem getting 500/503/502 errors, switches on flashes up then switches off, then sometimes switches on okay but no speed, speed sensor seems okay
Bearing Man
Ebike Motor Centre
945
2,273
It sounds like it’s got water on the circuit board, if you want any chance of saving it, don’t switch it on again! Especially after being upside down (pcb is at the top). Motor needs stripping and drying if you suspect water could have got in there. Get a warranty decision before opening motor but don’t take too long!
cablepuller1
12
GB
Thanks for info, if its the board is it a write off
Voluptua
103
65
United Kingdom
Given that the newer motors are smaller than the old ones, would it be possible to engineer an adapter bracket? Are there published drawings of the mounting arrangements?
Not necessarily for this instance, but to keep things going if the supply of Gen2 motors dies up.
Bearing Man
Ebike Motor Centre
945
2,273
It would be simple, but by the time your battery is 8 years old and you pay £900 for a gen 4 motor, plus all the agro of fitting it. Would it really be worth it? In a few years time, ebikes with frame mount batteries will look like penny farthings the speed things are developing. Also, we are hoping to develop a fix for anyone who has sentimental value in their old bike and really wants to keep it ??
Old Mike
58
48
Consett, County Durham
This is absolutely true.
I have a 2017 cube 160 travel ebike, external battery. It looks soooo old compared to the modern bikes.
But then I look soooo old compared to most mountain bikers so it suits me.
If i hadnt wrecked and scratched and crashed it myself (which i have) I still dont think it would be worth much, it just looks like yesterdays technology.
As it is it looks like yesterdays technology thats been ridden and maintained by an idiot.
I dont believe in internal routing of cables. All Hail Monster Tape!!
Bearing Man
Ebike Motor Centre
945
2,273
I cant believe no one hasnt created a adapter to put the new motor in
We have been looking at this. We made several brackets but as each bike is different and crank alignment, pedal height, chainring alignment and aesthetics all have to be taken into account, it was never worth the trouble and time. :confused:
Bearing Man
Ebike Motor Centre
945
2,273
How can you recondition it if you can't fix it?
Not trying to be a dick, just a genuine question.
we recondition working motors that we buy and keep to offer people if we can't fix their motor. Then we normally offer a part exchange on their motor, strip it for any usable parts and recycle/scrap whats left.
Planemo
605
706
Essex UK
Ah, gotcha. So you make a complete reconditioned motor from several other motors, rather than reconditioning just a single, 'non-repairable' motor (which was what threw me).
Cheers.
Bearing Man
Ebike Motor Centre
945
2,273
Nope, we buy a motor that may have a bearing failed or no problem at all, but we have to give it a full overhaul just for piece of mind. We try not to mix and match motor parts unless absolutely necessary.
Planemo
605
706
Essex UK
OK so you do a bit of both then.
It's not a problem, I'm sure glad you guys are around. Was just trying to work out how you got 'reconditioned' motors out of 'unfixable' ones, thats all.
545K
