Bike / Product Year: 2022
Manufacturer Rockshox
Model Gold 35RL 150mm travel 29inch wheel 44mm offset suspension fork
Asking Price £300 inc postage to UK
Location manchester, uk
Description This is a brand new Rockshox gold 35 rl 29 inch wheel, 150mm travel suspension fork, full specs below.
Steerer tube length : 190mm
This was taken off my new bike before it was ridden. It is fitted with a crown race, but I can remove this before I post it out if you want. The star nut is also fitted.
Full specs (taken from rockshox website)
MODEL DESIGNATOR (SF) | RL |
WHEEL SIZE | 29" |
TRAVEL (MM) | 150mm |
DAMPER TYPE | Motion Control |
FORK OFFSET | 44mm (29") |
MAXLE INCLUDED | Maxle Stealth |
COLOR (FS) | Diffusion Black W/Stealth Decal |
E-BIKE APPROVED | E-bike Approved w/E-MTB Decal |
STEERER | 1.5" Tapered |
AXLE | 15x110mm BOOST™ |
AXLE TO CROWN (MM) | 567 |
BRAKE TYPE (FD) | Disc |
CROWN MATERIAL | Forged, pocketed aluminum |
UPPER CROWN TYPE | n/a |
LOWER LEG TYPE | Magnesium |
UPPER TUBE FINISH | Fast Black |
UPPER TUBE TYPE | 35mm straight wall aluminum |
DAMPER ADJUST | Crown |
DAMPING ADJUSTMENTS | Extl rebnd, low speed comp to lock |
VOLUME REDUCER | 0/2 Tokens |
SPRING | DebonAir |
SPRING RATE | n/a |
MAX TIRE DIAMETER (MM) | 768 |
MAX TIRE WIDTH (MM) | 81 |
MAXIMUM ROTOR SIZE | 220mm |
MINIMUM ROTOR SIZE | 180mm |
FENDER COMPATIBILITY | Full or Short, 3 point and 2 point mounts |
CROWN OD (MM) | 61 |
PART WEIGHT (G) | 2341 |
