brake up grade E160s 2024
muddy Kev.34
19
16
bristol
just bought a set off magura mt 5 with disc. just wondering if i need to drop the motor for the rear break or could i maybe pull the cable back threw ??
Mik3F
465
424
Middleton
Connect the old cable up to the new one with a barb and see if you can pull it through
Has anyone actually tried to use the original brake cables with a different set of brakes, assume it may be possible to flush the cable with water and brake cleaner to flush out the dot fluid completely
If possible would certainly be easier
559K
