Brake Rotor Size Advice
Muzza
124
172
New Zealand
Quick question to all, having just put new 4 pot XT brakes on my Levo,(front & rear). I read that alot of riders have 4 pot on the front & 2 pot on the rear to even out the braking as the front does the majority of the stopping?
I'm wondering if I should go for the Shimano Ice Tech Rotors with a 180 mm rear & 203 mm front rotor to counter. Or perhaps have 203 mm both front & rear?
Any advice would be appreciated.
slippery pete
163
241
There is some degree to which it depends on the type of riding you do. The idea that the front brakes do all the stopping is incorrect for steep technical riding for instance.
I run all my bikes on 200/200 at the moment because there are situations I take them into where a 180 rear just isn't enough.
Balancing the brakes through rotor size isn't needed. Your brain is better at working this stuff out than you give it credit.
Flatslide
265
250
Dunedin NZ
Yeah, 203 both ends and squeeze the rear less hard. More braking leverage is nice on the downhills, especially with a weighty bike :cool:
Mteam
1,870
1,807
gone
On my orbea I have shimano xt 4 pots with 203mm rotors front and back and it feels fine.
But on my other bike with sram code rsc brakes I have 203 on the front and 180 on the back. I did try it with 203 on the back but it felt too grabby, too easy to lock up on loose surfaces, so went with 180 on the back.
The sram codes are more powerful than the xt's though so maybe that explains why I prefer a smaller rear disc with the codes?
Muzza
124
172
New Zealand
Thanks, I think you are right on the money, as my riding advances into the more technical steeper downhills I may regret the 180 on the back so easier to just play it safe & keep to 203.
deksawyer
387
452
Fife, Scotland
I have a 223 front and a 180 rear. Works very well for me. Both Magura 2 pots as well.
I was gonna put the 203 I removed from the front on the rear, but the rear was so good, I didn't see the point of fitting a bigger rotor.
Dirk74
99
55
Beside the personal preference it also depends on what is the largest size that the manufacturer approved for the bike.
Going larger than that could lead to something break at riding resulting in bad injury. Losing Warranty as well.
Muzza
124
172
New Zealand
Good points Dirk74, original rotors were 200mm so not much difference other than manufacturer brand.
I wouldn't go 180 on the rear, the weight of an emtb means it starts cooking early if riding hard - I run 220 up front and 200 out back. Interesting article here on rotor sizes, you can see some of the DH World Cup riders are going 220 rear and 200 front now too in some of the recent bike checks on Pinkbike and the like. Myriam Nicole being one example
Interesting article on rotor sizes here:
Muzza
124
172
New Zealand
Thanks heaps, will now look around to see if I can source a 220 rotor for the front. Don't think Shimano do them but maybe Hope?
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
Yeah, and it is kind of a fallacy re the front having the most stopping power - that's dependant on the surface. I use my rear brake much more because often I'm in loose stuff, slow manoeuvring, or trying not to hinder the front rolling over something or when I'm near the bottom of a steep rock slab etc. I always have to replace rear pads first. Now, if I was riding on the road - totally different.
Al Boneta
Dark Rider
1,351
2,602
California
Hope rotors will likely rub against the inside of the brake adapter and caliper. Galfer makes a 223 that I just tried out and the braking doesn’t seem any better than a 203 Icetech rotors
Muzza
124
172
New Zealand
Cheers again, great to get advice from members that have experience with different rotor sizes. Now think I will just play it safe & get Ice Tech 203 front & rear. Plus down here in NZ our options are pretty limited.
Muzza
124
172
New Zealand
Thanks for the great advice, slow technical is where I'm heading & I believe I will also be relying just as much on the back brake?
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
I'd say more. It's a common technique to drag the back brake while keeping the power on while doing slow manoeuvring. It gives you a lot more control. Consider a track stand, which is extreme and generally both brakes; that sort of control in technical stuff. Even riding skinnies - drag the rear brake a bit to help keep you straight.
Philly G
692
517
New Zealand
Thanks R120 for the links, super interesting ?
I would add in that a lot of its to do with individual technique too, there's no best solution for everyone - I for example use the front brake for stopping, and the rear brake for adjusting the attitude of the bike so to speak, which is a habit kinda ingrained in me from years of riding road motorbikes, along of course with where and how you ride.
Shjay
835
491
Kent
I am running Magura MT5s with 220 MDR-P rotor on front & 200mm MDR-P rotor on the rear, great setup
flash
1,050
986
Wamberal, NSW Australia
Very happy with my XT brakes and 203mm hope rotors front and rear. 23kg bike and 96kg rider and it brings me to a rapid halt when I need and I never fear running out of brake. If I were a more downhill orientated person I'd probably go for 220's front and rear. I'd rather be a bit over braked than underbraked.
Gordon
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
I’d like to say that I talked to some German mtb testing engineers and they said trickstuff breaks on 180 rotors break better-all-around than 220/200 for every other brand. Only 16 more month wait for my breaks.
—I’m in Stuttgart, where the SL motor is made.
I would be surprised if they said anything else - they're promoting their product. Now, if it was tested and the results shown...
Cavi
376
123
California, usa
I have 4 pots on front and rear, and currently 200 front and rear, but I just ordered a 220 for the front, I weigh 220kg and went on a long descent this past weekend and definitely felt that I was loosing some power twords the end, I was worried I was boiling
All4Fun
106
46
the Netherlands
Nice set up mate, Magura offer a bit of color choice as well I believe?
Same components here, only difference that i run the 200 at the front and the 220 at the back on my Flyon.
Organic front pads and metal rear.
I've used this in the mountains of France and i like this setup, enough stopping power and speed control at long 25% and more desents.
And yes colored rings too... :cool:
De groet'n...
04fuxake
321
205
Porirua, NZ
Dragging the back brake totally transformed my uphill switchback riding.
jbrown15
792
656
Chilliwack, Canada
I upgraded the brakes on my bike from Sram Guide RE's with a 220mm front and 200mm rear to Shimano XTR with front and rear 203mm Ice rotors. I'm much happier with the XTR's, better modulation and the rotors run much cooler than the steel SRAM rotors. Which I completely cooked in two riders, mean while the Shimano Ice rotors are still going strong.
I'm going to change out my hubs soon and go with something that offers a center lock setup and then I'll switch out to Shimano Freeza rotors which run even cooler than my Ice rotors. For me I'd rather have a 203mm rotor that runs cooler than any other 220mm rotor that gets cooking hot causing the brakes to fade due to heat.
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
For sure, but I think bigger rotors run cooler than smaller ones.
schleprx7
25
14
SF Bay Area
Good luck finding rotors larger that 180mm with Centerlocks. I ran into issues finding 200mm or 203mm rotors that I run on my non-ebike when I bought some new wheels a couple of months back. Ended up using adaptors so I could use 6-bolt rotors on my centerlock hubs.
In regards to using Hope 220 rotors, you should have no issues with clearance on the forks. I've used these with Fox 36, Rockshox Lyrik and Marzocchi Z1s. Your more likely to run into clearance issues with the rear brakes, where the post mounts on the frame and any adapters can interfere with the large rivet? that Hope uses to secure the brake surface to the aluminum carrier.
554K
