sirshan
So Im new to swapping and bleeding brakes - just never really did this stuff in the past because I haven't had a need to.
Question - I currently have a 2019 Levo FSR - Level T Brakes that Im not a fan of. Im getting ready to swap them to Code RSC Brakes.
Since the Hydraulic Cables are already routed, is it ok to disconnect and reuse those hoses without removing and just swapping the levers and the calipers? I assume connect points will be roughly the same, so Im not expecting Id be short anywhere. I know Id have have to slap some fluid and bleed...but it would save time on routing cables.
Let me know - life saver if I can reuse. Im too lazy run the new housing if needed and would just send it to a shop.
