brake pads and rotors in matched pairs?
Mr President
278
206
monmouth,wales
I plan to use my Ebike for different purposes and will swap wheel out between activity types.
Do you think that I should swap brake pads at the same time as I swap wheels in order to keep the rotors and pads matched? Similar to chains and cassettes which wear in together.
Mteam
1,864
1,801
gone
no need, its fine to mix and match.
edit : assuming that the braking surface of both discs are not smaller than the pads themselves - which really should never be the case, but you never know
6,534
5,010
Brake pads deposit a sacrificial layer of material onto the disc when they are being broken in. So provided both discs have been used with the same compound of brake pad ( e.g sintered) they should work equally well.
552K
