Levo Gen 2 Brake issue (2020 Turbo Levo)
encinoman
25
13
Los Angeles
I've had my 2020 Turbo Levo Comp for about a year now. It's been mostly great. Recently the rear brake started rubbing. It appears that the pistons are not retracting like they should. I took out the pads and treated each piston with a bit of DOT fluid. I cleaned them with a swab and worked each of them individually to make sure they move freely. Then I bled the brake line. However, they're still rubbing. It looks like the pistons on one side are stronger and actuate more than the other side. Any insight? Anything I should try that I haven't already? Is it worth the time and effort to rebuild the caliper and replace the seals and pistons or should I just replace the caliper?
Thanks in advance.
553K
