Brake hardware (screws etc)
p3eps
1,978
2,394
Random question...
Does anyone have conical washers on their rear brakes?
For the last 3 years I've just had standard bolts with a washer straight through the brake and into the frame. I don't have any postmount adapter on the rear (180mm rotors) but have never had an issue. The bolts were tightened up with the brakes applied, and there is no rub on them. MT7's - so minimal clearance too.
My front rotor is 203mm, and I have the conical washers on the screws for that. The front ones take a lot more effort to get the clearance on the rotors.
I was away to order some nice shiny titanium bolts, and wondered if I 'should' have the conical washers on the rear too?
Yes. All my caliper bolts (front and rear) have the ajustement washers, also called cup & cone washers. They sit under the bold head and look like this:
p3eps
1,978
2,394
I have them on the front, but not on the rear. I had a look on google at manufacturers stock photos and most have them on the rear.
I did wonder if they were only a requirement if you had a post mount adapter for your brakes though - which was maybe why I don’t have them at the rear?
p3eps
1,978
2,394
Thanks! I guess that's why I don't have them on the rear, as my mounts are parallel to my brake.
I'll order some anyway - won't do any harm to have them.
554K
