Brake caliper adapters...HEEEELLLLLPPP...!
Nick314
101
46
Monmouthshire
Morning!
So, added new forks and I've realised the mount points are quite different on the 22 vs the 21 Fox Float. So, whilst the front now feels awesome, I have no front brake bite...or v little!!
Can anyone just help me identify the right part please. The new fork has two identical mount points, the old one had a reduced one at the bottom, the result is that the brake caliper is being held too far away and only biting about 40% of the pad surface if I add the old adapter.
If anyone knows if I've ordered the right part I'd be v grateful... 🙏
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,506
2,224
England
Are the new forks 200mm rotor direct mount and your old ones were 180mm rotor and needed a 20mm adapter?
Or
160mm rotor and needed 20mm adapter to 180??
Nick314
101
46
Monmouthshire
This was the correct one - even th shop didn't know, but I took it anyway and its spot on. If you get one, it MUST have the new long and short(er) bolts supplied as they've change how they connect, ie: not 4 bolts
Not sure on the old ones as they had an adapter from new. I know the new one is 180 direct. I'm running 203s and the adapter sorts that.
551K
