Swissrider
When I bought my Rise H30 I had the shop update my front brake to a 203 rotor with STX 4 pot callipers. They had a lot of problems fitting this and had to take an adaptor off another new bike. When I came to change the pads I found that there was a strip about 2mm wide which had not been worn so clearly the calliper was too far away from the disk so the pads were not engaging fully. Checking the Shimano site I noticed that the shop had put the two cone washers between the adaptor and the calliper rather than between the head of the bolt and the calliper. However, when I mounted the callipers correctly the calliper touched the outside of the disk and the wheel would not turn. So, I took it to the shop who were mystified as to what had happened. They told me that the original rotors were 160mm and they made a mistake upgrading to 203 rotor and it should have been a 180mm. I knew this was wrong and didn’t want to lose the advantage of a 203mm rotor so suggested that they fit washers to put the calliper in the correct position. After about an hour and a half they achieved this. However, this seems a bit heath-robinson and my suspicion is that the adaptor is the wrong one. Maybe it is for a 200mm rotor and I need one for a 203mm rotor. I have found Shimano 203mm adaptors on line but I’m not sure which one I need.
- black/PM 6" to PM +43 mm, in stock
8.14€
- black/PM 7" to PM +23 mm, in stock
11.76€
- black/PM 8" to PM +3 mm, in stock
9.95€
Any advice please
