As well as position of the output shaft in relation to the bolts, or chainstay lengths would get all messed up when swapping as well.Even if the bolt pattern is the same, many frames are designed to fit around the casing so it's unlikely you can just neatly stick a DJI into a Bosch frame. A proper standard will require that casing dimension are somewhat uniform between manufactures.
