Bosch Mini Remote eating batteries
mudpup
England
Just picked up my new bike equipped with a Bosch Mini Remote and have completed 3 rides of about 20 miles each. The Mini Remote seems to be eating its battery - I've just had to replace it today. It was at 31% after the second ride and dropped to 9% on the 3rd ride. Anyone else had this or any pointers to what it may be?
pinoymamba
47
30
I just ordered one so I can tuck away the giant controller into the frame. I'll let you know if I come across your issue.
map Leeds
leeds
Did you ever find out what the problem was as I’m having the same issue 3 battery’s replaced within 170 mile of use on a rail 9.8 axs
6,551
5,041
The mini remote communicates with the controller via blutooth which should mean the battery is only in use for the very short periods of time a button is pressed...and should last years! I would therefore assume either water has got into it and it is permanently transmitting, a button is stuck down, or it is simply a faulty unit. You could try removing it and leaving it in an airing cupboard..perhaps on a bed of rice in a plastic container for a day or so..............or alternatively getting it changed out for a new one.
Mario Antony
225
172
Portugal
If the battery drain completly, disconecting from ebike, motor will stop working and a error will appear.
It seems you have a faulty miniremote
Stihldog
Handheld Power Tool
3,540
4,964
Coquitlam, BC
…perhaps on a bed of rice in a plastic container for a day or so..............or alternatively getting it changed out for a new one.
Soooo, no need to do this then?
6,551
5,041
no...the mini remote is merely a means to communicate with the controller remotely. If it stops working it would have no impact on the controller but would not communicate with it. you can still use the controller to change modes etc.
554K
