Bosch Gen 4 free wheel
Doddy
Bradford
Morning all.
I have a Bosch gen 4 motor , 1700 miles 2021, warranty has just run out and the free wheel is sometimes locked in, locked out, when you back rotate the pedals it is really lump, like the teeth in a standard hub, anyone else have a problem like this, is there a fix, heard spares are hard to come by, can anyone recommend a repair service.
Thanks Phil.
Bearing Man
Ebike Motor Centre
973
2,322
Morning all.
Thanks Phil.
If the issue is with the freehub in the back wheel, the chain will go slack on top (provided you have a derailleur system) If this is not happening, then as the others have said, it is probably motor related. This is a common issue on the Gen 4 because the crankshaft rusts and starts to become tight in the freewheel sleeve within the motor.
To check this: Remove the chain, hold the front chainring and turn the pedals backwards. The crank should be relatively free moving and a clear crisp ratchet sound should be heard.
yorkshire89
468
663
North Yorkshire
Cranks on a Bosch gen 4 should spin backwards without moving the chainring/chain, so sounds motor related.
I'd take it to a Bosch service centre and let them send diagnostics off to Bosch. They might come good being just out of warranty...
554K
