Bosch gen 4 beep after turning off
nick155tm
Uk
Hi,
Has anybody had an issue with there ebike beeping once After switching it off, it's a bosch gen 4 system.
6,850
5,292
No...not on the Bosch Smart version or the previous Purion controller system. I suspect the beep is generated by some ancilliary extra you have fitted to the system......lights/connect module etc.
Oct 29, 2024
65
72
Yorkshire
Hi,
Thats normal IMO. You've likely enabled the smart system lock function, in the flow app. If you turn it off again (or turn your phones bluetooth off so it cant connect to the bike) it ought to stop the beep when you turn it on, and turn it off.
nick155tm
Uk
Smart lock definitely not enabled.
That's first thing I checked,
franciscoasismm
268
293
Badajoz
The beep after turning off a Bosch Gen 4 motor is likely due to the **eBike Alarm feature** being activated. This function, part of Bosch's Smart System, provides theft protection by automatically enabling an alarm when the bike is powered down[6][8]. You can disable this feature through the Bosch Flow app or by turning off your phone's Bluetooth if it’s linked to the system[6].
Referencias:
[4] Bosch Performance Line CX, bad motor noise, every bearing changed! [6] Bosch gen 4 beep after turning off - EMTB Forums Bosch gen 4 beep after turning off
[8] eBike Alarm eBike Alarm
576K
