Bosch cx 2020 cutting off early
Lmcdk
Denmark
Hi. I have a Cube emtb with the bosch cx2020 engine and purion display. When the display shows 25-26 km/h and cuts the power, My GPS shows 22-23 km/h. Does anyone know how to get the last speed back? The shop where i bought the bike cant help, and everything is mounted correct. Im not looking to tune/derestrict but im missing the last speed when ridning with others.
Jona
101
44
Belgium
i have the same issue. LBS said he could change it (I think he's lying, it must be possible to tweak if you change tires E.G.) i would like to know i it is possible to read out wheel size or circumference on a purion. anyone knows?
Darren66
130
91
uk
Not possible on the Purion display, I believe the Kiox has approx 5% adjustment for tyre size.
Bosch are just erring on the side of caution, if the display was true, any tyre changes would possibly make the bike illegal.
My Bosch Purion reads approx 1.5mph faster than my Garmin (doesn't really matter, as I have a Speedbox 3.0 fitted)
Lmcdk
Denmark
Danm. Thanks for your answer.
Doomanic
🛠️Wrecker🛠️
8,687
10,314
No adjustment in the Purion and only 5% in the Kiox. Best off getting the LBS to do it and then using that 5% to push the limit slightly.
551K
