dixie600mhz
Just a heads up that if you have a bontrager dropper post that's slightly too long you can insert a 10mm or 30mm shim (just like the idea behind the one up posts). I've read that you can't insert more than one shim at a time but you could shave down material from the 30mm to suit.
After I switched out my bontrager seat for an ergon core plus my dropper was slightly too high. I popped in the 10mm shim and it's working great! Fits perfect again.
Note the shim goes in under the black insert collar.
