do you mean shaft diameter? an interesting point, is it smaller than the van or larger. if you meant length thats not a problem as it can be spacedI don't know the details but I believe shaft size is different to the VAN. (it certainly has different seals) and internals are supposedly not quite as sorted as the RC4 so possibly a good middle ground. ??
still depends on the levos LC and progression which shaft size would be the best choice though.
Yes diameter.do you mean shaft diameter?
