Bomber CR on an E-Sommet 297?
CJaMTB
402
381
Dartmoor
Anyone running a Bomber CR on a 2021/2 E-Sommet? Thinking of getting one, to try the coil ride (am hoping the leverage curve is progressive enough to accommodate my knees!), but curious as to whether the reservoir will clear the frame on bottom out. It looks like it should, but thought I'd ask in case anyone knows different..?
Cheers.
dave_uk
103
53
uk - Staffordshire
should fit as the Bomber looks similar to the Fox I fitted:
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Leverage curve on the 2021 ESommet is a fair bit more progressive than on the original (18/19) Esommet frames and as such far more suitable for a coil shock.
Not sure what you mean regarding your knees though.
CJaMTB
402
381
Dartmoor
Leverage curve on the 2021 ESommet is a fair bit more progressive than on the original (18/19) Esommet fames and far more suitable for a coil shock.
Both knees, right ankle and right hip were injured in service. I now have little padding in the knees, so rely on quite progressive set-ups to compensate. I'd read about the increase in progression, over the original bike, so am hopeful it will work out. Worst come to worst, I could try a progressive spring, though not sure I 100% believe in them!
Gary
Old Tartan Bollocks
10,496
10,702
the internet
In that case. You might actually be as well sticking with air. But that will depend on what shock you're currently running and what exactly it is you aren't liking about it's performance.
CJaMTB
402
381
Dartmoor
I've got a 2022 Float X2 Performance Elite, which is my favourite shock of all time. Had one on a Kenevo previously and knew I needed one on this E-Sommet. Tbh, the coil thing is more like my determination to keep riding hardtails - I knew it was a dumb idea but I just couldn't shake it until I'd proven to myself just how dumb!!! 😂
InRustWeTrust
524
758
Sweden
CJaMTB
402
381
Dartmoor
Can anyone confirm for me if this is all I need for a new shock to mount to the 2021 E-sommet?
No, you would also need the lower bolt and the bushings and mounting hardware. What you have in this link is just the upper two bolts that fit the Trunnion mount on the shock.
MadTurnip
57
25
Dublin, Ireland
Thanks, I figured it out. The lower shock mounting hardware and bushing are 8x30 for the Vitus Esommet 2021.
This is what I bought in the end:
552K
