Mike D.
I found that I needed the expandable attachable strap to keep them in position. I don't have a very "bridged" nose so they just slip down without it. I have prescription inserts and they are kept in place by being between the outer and inner frames, so you can't take out the rear frame and use them without it... However, for riding they are perfect. Stayed in place under the most extreme pressure, completely wind and dust-proof.
The air-con slots in the outside edge of the inner frame work well at avoiding misting up whilst on the move. To glance behind, you'll need to turn your head more - the thick frames reduce peripheral vision slightly.
If you are in cold air, they'll mist up if you stop moving, but then just loosen the strap to lose the frame/face seal.
I bought online from safetyspecs.com
