Bike weight
Reuben
41
20
TN40 1RL
Hi guys
I'm trying to find out the exact weight of my cube stereo hybrid 160 SL 500 - I have the 16" frame.
Need to know the weight WITHOUT the battery.
Any ideas where I can get this info? I have no means of weighing it but need to know for a flight.
Thanks!
Jan 11, 2019
65
60
Thirsk
Hi guys
Thanks!
I have used a fishing scales I had from go outdoors my 140 stereo is 20.4 without the battery so yours will be close if not lighter with the carbon bits
preedy62
12
Hi guys
Thanks!
Use bathroom scales first with just you then with you and the bike ??
Just weigh the battery then subtract it from the listed weight for the bike, which I believe is 52.4lbs (23.7kg) - if you can't do that I believe the battery weighs 6.3lbs (2.85kg) - i.e the bike should be circa 45.9lbs (20.85kg) without the battery
553K
