Levo Gen 3 Bike floor stand recommendations
Sarends
Colorado
Do you all have any recommendations for a garage bike stand? Not a mechanic’s stand, just something so I don’t have to lean my Levo against the wall. Thx!
Chris6
28
26
South west
This works well .
unclezz
193
97
CZ
Go for a Stabilus 2.0 or the classic Stabilus 1.0 if you don't need to have a folding one...
You can easily find them on local shops online or on Amazon. I use them for both e-mtbs and analog bikes. They are rock solid and not too big.
DanoC33
What are you looking to spend? I have a floor stand like some of the others pictured and found it to be ok for a Levo but easy enough to tip over. I decided to go with one of these NEW BIKE STAND 8MM SHAFT - Bolt It On - Your Motorcycle Tie Down Rack System! and have been very happy with the quality and the way it works on our Levo's. I use this stand for pretty much everything now as it holds the bike secure with the rear tire raised so maintenance, washing, etc. is made easier. Not the cheapest option, but worth it for these heavier bikes.
SteveTTT
49
35
Hampshire, UK
I got an XKL Fat stand as a freebie when I bought my Giant Trance X Advanced E+2. Tbh it’s fine for parking the bike but not stable enough if you’re doing work or cleaning - if the bars turn it can tip the stand and bike. I put some thick 50mm dia foam pipe insulation around the uprights and that’s helped a lot (it’s on 2.6 section tyres) although it’s not perfect. A mate recommends the Oxford stands.
552K
