brw0513
Hi All.
I'm getting better at this eMTB caper. And it seems "a bit better" translates to much more confidence and a whole lot more fun on the trails.
And I want to improve some more to justify my next eMTB purchase But at 188cm tall, I'm on the cusp for most bikes between the L and XL frame size.
My current bike is a 2018 Merida e160 900e in size L. Reach is 460mm; stack is 644mm. I'm 120kg (but losing weight) and about as flexible as a broom stick. And 54 years old.
When I started riding my local trails on the e160, I was spending $99 of my $100 brain just staying upright. Lots of bashing into and over things. Even things I could have steered around. No finesse at all and not a care in the world about bike fit. The bike/suspension was very tolerant and the E8000 just a tractor up the climbs.
But for the past 6 months or so, I've been wondering if the e160 Large is truly a good fit for my body. When I watch others who seem to float over challenges on the trails, they seem to be much more "in" their bike. I thought I could look more like that if I found an e160 in XL, and began looking.
It turns out that finding a 2018/2019 e160 in an XL frame size, here in Australia at least, is going to be very difficult. Maybe impossible.
But recently I've started to look at bike geometry more seriously. And I've drawn quite a few frames in AutoCAD using the published geometries. This made me realise that an XL frame might not be required. With my 160e in Large, I already feel I'm too stretched out in basic skills like lifting the front wheel and manualling. I was beginning to wonder if my bars needed to be closer but higher.
I've found the RAD and RAAD sizing method described/published by Lee Likes Bikes. It makes sense to me, but of course there are those on the other side of the argument.
The undeniable thing about RAD and RAAD, right or wrong, is that the measurements can be drawn in CAD. And then different bike frames in different geometries and different sizes can be superimposed for direct comparison.
As it turns out, my e160 900e Large frame can deliver a reasonable RAD and RAAD with appropriate choice of stem, bars and spacers. I'm going to try it to see how it feels. It will be a reasonably expensive exercise.
My theoretical RAD is 840mm; RAAD is 58 to 60 degrees. The RAD on my e160 Large, with current cockpit, is currently 890mm and approximately 55 degrees.
I'm interested in others opinions about RAD and RAAD who have done what I'm about to try.
And if you don't like RAD and RAAD, how do you size your frame and cockpit?
Good advice appreciated.
