It’s the Turbo Connect display Andy
Usual speed distance time. Battery level, mode selection, links up to heart rate monitor. Nice piece of kit.
Thanks for that I did read it is quite tricky to pair it up as you need the number on the on off switch which means unscrewing that! Is that correct?
My LBS set it up so don't really know. They did have to update it as it initially was not recording the miles correctly.
..I do recall they popped out the CPU unit. Works a treat now.
